97 Expedition- Intermittent hesitation and then it dies.
have a 97 that I bought off a friend of my wife- against my gut feeling
I ran it out of gas about a month ago and this when the problem started.
Once the fuel ran to about 1/4 of a tank it would start to miss then die
I would let it set for a while then it would crank up and run for a bit then the same results- this continued for about 2 weeks
Just some notes to keep in mind-
This was a total "Jerry Rig"- I apologize if your name is Jerry
The "check engine" light doesn't come on at all- Probably disconnected
Oh- I also found one of the vacuum hoses melted to the engine (now repaired)
I have read there is suppose to be a pressure release valve to measure the pressure- I cannot locate this and I believe it has been "Jerry rigged" out of the system, excuse me modified off the system.
If you have any further trouble shooting steps i would be greatly appreciative.
- It is now DOA
- Added gas treatment to the fuel- this seemed to sorta work
- replaced the fuel filter- this seemed to help a little
- Drained the tank of all the old fuel and replaced with 97-with NO Ethanol
- Unhooked the fuel line and turned on the ignition to see if the fuel was flowing (at the fuel filter)
- Turned over and squirted starter fluid in the intake (seemed to run, not well though)
97 Expedition- Intermittent hesitation and then it dies. *SOLVED*
There is no resolved area. It's enough that you came back to posted that changing the FP solved the problem. Alternately when making the follow-up post, you can change the topic/title to include resolved or solved like I did above this post.
mybadford
1997-2006 Expedition & Navigator
11-16-2018 09:25 AM
therealulysses
03-09-2006 11:53 AM
