Turn engine by hand?
Old Apr 22, 2013 | 01:37 PM
expydaddy's Avatar
expydaddy
Hey all, I have a 99 expy 4x4 with the 5.4 motor. I am preparing to change my tranny fluid and my torque converter fluid. How do you rotate the engine by hand so i can access the torque converter bolt? I have never done this before and any help/tips/ suggestions on fluid would be appreciated.
Thanks
Old Apr 22, 2013 | 02:42 PM
alloro's Avatar
alloro
Either a ratchet with a socket on the bolt in the center of the front engine pulley, a strap wrench on the pulley, or there's a special tool for turning the flywheel that your local auto store might have for lease.
Old Apr 22, 2013 | 03:09 PM
r2millers's Avatar
r2millers
Thanks
When turning, just make sure you turn it the same direction as normal when running to avoid damage.
I like the socket on the crank pulley the best as alloro mentions.
Old Apr 22, 2013 | 10:37 PM
Gevans17's Avatar
Gevans17
turn engine by hand
use a socket and 1/2 inch ratchet on the crankshaft pulley turns real easy
iron1951
Apr 28, 2019 09:48 AM
Encho
1978 - 1996 Big Bronco
Nov 9, 2012 12:25 AM
aerocolorado
Aerostar
Jul 19, 2007 04:23 PM
shw
1983 - 2012 Ranger & B-Series
Jan 27, 2005 10:31 PM
Rocking M
May 17, 2002 10:06 AM
