Brakes
Brakes
Hey guys, I am getting ready to change the brake pads on my 2006 F250. it has 70,000 miles on the original pads and rotors. I am starting experience a squeak when I apply the pedal. I am assuming that the rotor and pads are starting to get glazed over. I am installing Motorcraft pads. My question is, should I get my rotors resurfaced or buy new ones? Any advice would be great. Thank you!
on
1 Post
The major issue is going to be if you have any pulsation when braking, which would be due to nonparallel surfaces or hard spots in them. The secondary issue would be smoothness of the rubbing surfaces and amount of rust buildup in the cooling vanes.
The detriment of not providing a new, smooth (no grooves), but rougher (machined vs polished) is that it will take longer for the friction material to burnish into the surface since there will not be a rougher rotor surface to smooth down the friction surface, and the time it takes for the pads to wear into the grooves or micro grooves.
However, if I don't have any pulsation and the vane rust is not bad, I reuse the rotor as is. Instead of taking a week of driving to fully bed in they will take two weeks. For me, I can live with that. And if my rotors are too grooved, I don't bother turning them and just buy new.
If you decide that you do want to turn the rotors, please don't have that done on a bench lathe. They need to be turned with an on-car lathe so the runout is minimized and matched to the rotors. Excessive runout will make even the best rotor develop pulsation over time as the high runout points will wear thin, the result being non-parallel surfaces.
ABS light comes off and on.
I just replaced the brake pads and Rotors on my 2003 F250. I bought it used and I plan on using it to haul a 5th wheel. That's why I replaced the breaks and rotors. I just cant figure out why the light will come on. I also have noticed that the front wheels are really hot after driving a mile down the road. Any Suggestions on what I may need to do.
If the wheel heats up, the caliper is dragging and needs to be replaced. You can try lifting the wheel with a jack and spinning it, you can try pushing the pads back with a tool, but it's usually pretty obvious when the brakes get too hot to touch. One thing - often the caliper pistons only stick when they are hot, when they cool down they retract just fine but when they get a little hot they stick. For all the talk about flushing this and lubricating that, it's never worked for me. If I have an brake that's dragging and heating the wheel now I just order two new calipers and replace both on that axle - I never do just one side. If I am lucky the disc hasn't been damaged.
Brian
Brian
Brian
Brian
Brian
Brian
KMUL
01-10-2010 01:16 PM
