1990 F150 Not Starting
You can go to this link to find out more information on the TPS:
Fuel Injection Technical Library » Throttle Position Sensor (TPS)
If the computer thinks you are at WOT it will not fire the injectors while cranking.
The codes you posted seem like just the KOEO electrical ballpark test.
Maybe you have more codes in Computer Memory (CM) that will tell you more about what is wrong if you have not disconnected the battery.
jetskipilot36
17
02-18-2017 10:18 PM
sgauvry
691
02-09-2017 08:32 PM
jonjon2269
15
08-25-2013 04:54 PM
