1978 - 1996 Big Bronco
Problems Starting
Old Dec 7, 2003 | 10:01 PM
jodywill's Avatar
jodywill
Problems Starting
My father has a 89 Bronco with the 5.0 EFI liter engine.
About a week ago, it was running fine. Since then, the vehicle hasn't been started. A few days ago, he tried to start it and the battery was dead. After charging the battery (about a year old), it still will not start.
He doesn't have a manual for this yet. I pulled the codes earlier today. They were 21 and 24. I don't remember what they are exactly. I believe one is the Engine Coolant Sesnor and the other is the Mass Air Flow Sensor.
The truck acts like it is going to start but won't. It sounds like it isn't getting enough fuel.
When first turning the key on, I hear something that sounds like the Fuel Pump for a couple seconds. The sound is coming from just below the drivers side seat, on the frame. There is something that is about 6-7 inches long and is a cylider. It is slightly wider than the fuel filter. This has a fuel line on each one with 2 electrical connections on the front. Is this the fuel pump?
I thought the pump as actually in the tank.
In the morning, I am going to change the fuel filter (about 2 years old). I just happen to have one laying around.
How is the easiest way to make sure this isn't a fuel problem?
Any suggestions where to go from here?
Thanks
Jody
Old Dec 7, 2003 | 10:28 PM
Red_EB_Bronco's Avatar
Red_EB_Bronco
well, I can try and rule out the mass air flow sensor, b/c I dont think they put those on untill the 93 or 94s, i'm not completly sure when they put them on but I know your truck doesn't have it unless its aftermarket parts for the mass airflow convertion.
It should be a speed density setup.
how did you pull your codes?
chim in guys, give her that site on how to pull the codes.
also, your truck has two pumps, one on the driver side frame rail(high pressure), and one in your tank(low pressure)
Old Dec 7, 2003 | 10:32 PM
jodywill's Avatar
jodywill
I pulled the codes using one of the Code Scanners & watching the check engine light.
Old Dec 7, 2003 | 11:05 PM
AYoungblood's Avatar
AYoungblood
CTS!!!!!!!!
Well do me 1 favor before i get excited.
Crank it abotu 10 times, then smell the tail pipe and near the throttle body.
Do you smell a crap load of fresh gas?
If so im 99% sure its your CTS. Your TPS really should make it not start, if anything it would start and stall if to low, or start and run at 1000rpm+ if to high.
If you dont smell ANYTHING, then your gettin no fuel, prob pump.
Go under you car, drivers side frame rail and pull your fuel filter, and then blow it out, onto a table or something. If it really nasty that means it hasnt been changed in a while. Not good. Now with the fuel filter disconnected, (you'll need 2 ppl) turn the key to start. BUT! VERY quickly. When you turn the key to start you should hear you fuel pump come on. It is trying to meet the PSI that your FPR is setting. Now with it all disconnected the fuel pump (if working properly) will not shut off.
So 1 person turn key, 2nd person lay under car, away from fuel line, unless you want gas on you and listen for pump and watch from gas to be SHOOTING out of that line. If it shoots out GOOD! If not... Huston we have a problem.
Well good luck!
Adam
P.s.
You pulled the code correctly.
Old Dec 8, 2003 | 02:09 PM
jodywill's Avatar
jodywill
Since CTS was one of the codes reported, I changed it.
I have also changed the Fuel Filter. While the filter was off, we checked that the fuel pump was working. It sprayed as expected.
After changing the Fuel Filter and the CTS, it still will not start. There is spark going into the Distributer Cap. The Distributer cap and Roter were both changed this past summer.
Any other idea's?
Old Dec 8, 2003 | 02:17 PM
luckild's Avatar
luckild
Have you tried a starting aid? CTS can come up because coolant is cold. Do you have a way to check fuel pressure?
Old Dec 10, 2003 | 05:13 PM
jodywill's Avatar
jodywill
I haven't tried any starting fluids yet. At the moment, I do not have a way of testing fuel pressure.
With the Fuel Injection, how is the best way to use a starting fluid?
Thanks
Old Dec 10, 2003 | 05:20 PM
luckild's Avatar
luckild
Give it a shot at the air cleaner or inlet hose, which ever is easier to get to.
matowns21
60
Jan 3, 2012 10:36 AM
Deadeye1445
Sep 7, 2009 06:15 PM
darkwingduck
Nov 27, 2006 07:00 PM
Colossus
Dec 30, 2003 03:04 PM
Momudder720
Apr 22, 2003 07:56 AM
