1990 F150 Not Starting
Old 03-16-2013, 02:33 PM
subford's Avatar
subford
subford is offline
You can go to this link to find out more information on the TPS:
Fuel Injection Technical Library » Throttle Position Sensor (TPS)
Old 03-16-2013, 04:48 PM
farmtruck101's Avatar
farmtruck101
farmtruck101 is offline
Thanks
Just a questions:
Can the TPS suddenly prevent the truck from starting and causing the symptoms I see?
Looks like the whole TB will have to come off to replact the TPS?
Old 03-17-2013, 08:01 AM
subford's Avatar
subford
subford is offline
If the computer thinks you are at WOT it will not fire the injectors while cranking.
The codes you posted seem like just the KOEO electrical ballpark test.
Maybe you have more codes in Computer Memory (CM) that will tell you more about what is wrong if you have not disconnected the battery.
jetskipilot36
17
02-18-2017 10:18 PM
sgauvry
691
02-09-2017 08:32 PM
cargoflyr69
1983 - 2012 Ranger & B-Series
12-08-2013 11:17 AM
jonjon2269
15
08-25-2013 04:54 PM
jodywill
1978 - 1996 Big Bronco
12-10-2003 05:20 PM
Quick Reply: 1990 F150 Not Starting
