"Wimbledon" white in a spray can?
If that doesn't work, some automotive paint stores have the ability to mix paint and put it in a spray can for you. It's more expensive than a can of Duplicolor but definitely cheaper than buy a spray rig if you don't already have one.....
Advanced Auto in San Antonio stocks Duplicolor Wimbledon White for around $8. They keep a maximum of 3 can per store so you may want to call and see if the store closest to you has it on the shelf. They also have a clear coat if you want a glossy look.
I have had good results with the Perfect Match paint on a bumper. It is not a perfect match for paint on my custom paint job. But the paint shop mixed there own paint and the bed color is different from the tailgate which is a different color than the cab. (Another long bad story) The Duplicolor is the real WB color. There are lots of lines and transitions in the cab for you to blend a color difference. Or you can paint the whole cab with 4 cans for less than $40.
Wimbledon White in a spray can?
Be aware that there was another shade of white available for these trucks: Pure White, COLOR code C
FTE member camperspecial65 has the rarest of the rare. COLOR code: MC = Tu-tone white!
And, be aware that 1961/63 COLOR code M applies to Colonial White, not the same shade as Wimbledon White.
But, I don't think 6t6Merc will have that problem.....
FoMoCo confusion: Cars may have a different color code than trucks for the same color! Lincoln may have different code than Ford/Mercury for the same color.
FoMoCo changed color codes more often than women change their minds!
I had a 1964 Galaxie 500XL F/B, it was fugly Pagoda Green. Bought it in 1975 from the original owner, trans man at Wray Bros. Ford in Van Nuys.
Thanks all... I will heed your advice but first I will test freebies I got today: "Ivory", "Antique" white, and Toyota "special" white (I don't know how that last one came to be in a rattle can.). Preliminary testing shows none is refrigerator white, and since nothing else on my truck is any kind of white, any one of them might be ok.
I agree, CM-2 is likely the rarest. My Merc came 8M-2 which is at least very uncommon.
Eric
Eric
Wimbledon White is an off white, not reefer white. Studebaker used the same color on 1961/64 Hawks, but called it cream.
1966 Mercs use the same VIN, Warranty Plate and codes stamped on it as US trucks. Look on the 2nd line of the Warranty Plate between the W.B. (wheelbase) and MODEL code for the COLOR code, post what it is.
Available from dearbornclassics.com located in Bend OR / 1964 and later Wimbledon White Warranty Plate COLOR code: M
I believe your are correct. I knew it was a "C" word - Corinthian, Colonial, something.....lol!
1963 Color Codes - Ford Paint Cross-Reference
65F100project
07-11-2023 10:57 PM
Grape Nehi
13
04-03-2018 11:54 AM
Midnite Cruiser
06-14-2002 02:21 PM
