what parts do I need for a brake job on a 1994 Ford F150 4x4
My brakes started grinding and grabbing about a month ago I noticed that on the driver side front wheel there was oxidation really bad and break fluid my brake light is also on and I only have brakes every now and then I am not driving it because of the breaks. I really need to know what parts I need to change the brakes.
It also needs a turn up and I need to know what I need for that too thank
for starters; calipers, rotors, front pads,brake fluid, inner an outter bearings and a seal for rotors. Are your rear brakes ok ? Tune up; plugs,wires,cap an rotor pcv valve ,fuel filter, air filter and throttle body cleaner, maybe also fuel injector cleaner. And check all your fluid levels, an air pressure in tires.
