Serpantine belt jumps off
I fail at searching. serpentine belt site: ford-trucks.com/forums/forum117/
My belt jumps off at startup even after:
New belts
new idlers
new tensioners
new tensioner bolt
aligning power steering pulley
What am I missing? It can be months with no issue, then...........
Is there a mod to keep the belt from slipping off the back side of the idler and tensioner pulleys?
New belts
new idlers
new tensioners
new tensioner bolt
A shorter belt seems to have solved the problem.
All pulleys measured close to spec and are aligned as close as I can get them.
The tensioner is the updated one.
I can't figure out what makes my serpentine drive want a shorter belt but that's what I'm running.
The indicator pointer is where it should be so.....
