Does a complete solution kit need a HPOP
Old 02-07-2013, 07:12 PM
h20ford's Avatar
h20ford
h20ford is offline
Hello
Wondering if I am updating my engine, with a River City Diesel Complete Solution Kit, is it worth my while to put a HPOP in there.
$600 with shipping unless there is a better cheaper outfit ?
I would like to do the injector tips, "O" rings as well.
The truck has 150,000 miles and the EGR has not been addressed.
My initial plan was to just do the EGR delete and Oil Cooler and New Water Pump, but it has snowballed a bit because I realize the importance of the head and studs and gaskets. Though none as of now show bad signs...yet !
The truck is behaving ok and is just lacking a bit of trailering up hill power.
The Oil temp is ok, boost is ok. I have egr codes, egr valve cleaned, back-pressure sensor clean. 58vficm Oil flush with rev-x.
So I may be missing something, but I want to be sure the injector "O" rings, connection from HPOP are ok, and it seems while in there, the head's and injectors is/are only a few steps further.
The VGT is newer and works but not great, it really works with-out load.
I do not need more power, but it is lacking.
I have a Auto-Enginuity and test Fuel Press, Oil Temp Boost and some others on a regular basis.
Any comments are appreciated and welcome
Thanks Folk, for reading my long worded statement.
also here is my list of to-do's, please add if desired
I what to delete the egr/block it, run the coolant back to the degas (or add the Kit), new straight uppipe to turbo new oil-cooler and water-pump, blue-spring, crank-case-vent-charcoal-canister
new injector tips, intake plenm gaskets
egr gaskets? no egr? I am deleting the egr (the only reason is because it is only fed from one side making it "mickey-mouse".
turbo oil lines, Turbo Oil Feed Line, Turbo Drain Tube
reverse flush coolant
Intake Gasket Kit
HPOP Screen and new pump????
oil cooler cover MUST be changed to the newer style (2004model-up) because the connecting point on the oil cooler cover for that line was redesigned
If the bend is smooth, then the drain tube is OK. If the bend has what appears to be a slight indentation in it, then that is the one to be replaced. So I think mine being a 03 has the old, then I need the 05 and up therefore need the new tube/line??? COMMENTS ???
IPR screen
upgrade to 05 oil filter vs remote oil filter
Thermostat
06, is the updated STC fitting on the HPOP mine being a 03 don't require.
Rotella T6 5w40 full synthetic
I hope that covers it,,,,,,,,,,,,
Old 02-07-2013, 07:20 PM
Bullitt390's Avatar
Bullitt390
Bullitt390 is offline
Certified Thread Hijacker
If it ain't broke don't fix it.
The only non "broken" item I would consider is an EGR delete.
Josh
Old 02-07-2013, 07:36 PM
h20ford's Avatar
h20ford
h20ford is offline
cool thanks
I am of that school.
The truck is a Wrecker/Tow in the wilds of B.C. Canada
There is no other for 600km, so I need it dependable.
Our family is going on vacation for 2 weeks and it could have some attention.
Just figured, the only other problem other than the egr is the Injector O rings that could really account for the poor trailering performance.
Kind Regards
James
Old 02-07-2013, 07:43 PM
Bullitt390's Avatar
Bullitt390
Funny things happens around here:
A guy's truck runs just fine, but figures he will upgrade this and replace that and next thing you know he ends up driving a bucket of bolts and should have just left it alone.
The #1 thing you need are gauges, whether Dashboss, SG2, Torque or AE.
Josh
Old 02-08-2013, 10:04 AM
h20ford's Avatar
h20ford
h20ford is offline
Thanks Bullitt 360
You would know, and I appreciate it !
so thanks !
That is why I purchased the AE, but running a Wrecker service I do see catastrophic failure on vehicles, my terrain is 800 miles. So I will need some dash gauges as the AE is cumbersome.
I am not running extra tunes, just stock. So there should not be problems.
I would like the truck to run for a long time, and I see a few weeks of down time as good to do preventive care.
Again, upon most peoples and Yours again (Thanks) I will continue my monitoring program.
Old 02-08-2013, 10:57 AM
Bullitt390's Avatar
Bullitt390
Full coolant flush and use a CAT EC-1 coolant. Your EOT/ECT temps would dictate whether you need an oil cooler.
EGR delete
With gauges you'll catch the other stuff ahead of time.
Josh
Old 02-08-2013, 01:04 PM
h20ford's Avatar
h20ford
h20ford is offline
Thank You !
Great, I believe the oil temps are ok.
When I purchased the truck in 2008, that was one of the things along with coolant filters fluids etc and purchased a AE to help.
I feel I have Limped it Along because I don't need a broken work truck I did not push anything, and they are great out of the box anyway.
Josh, would you prefer the EGR delete by way of straight up pipe or, blocking the old which hopefully has less ability to "Rattle" around. As I have read, some have a problem with a straight up pipe because it has nothing to hold it. But maybe that was a while ago, and flanges and technology has come some way in the last 2-3 years??
Appreciate everybody, Thanks again Josh
Old 02-08-2013, 01:15 PM
Bullitt390's Avatar
Bullitt390
I did the "stealth" delete by welding plugs in the old cooler.
I've heard of issues with using a straight up-pipe, but also there are plenty that don't have any problems too.
Josh
Todd77F250
02-06-2013 08:34 PM
m350
03-21-2012 08:09 PM
steelkiwi75
02-04-2011 03:03 PM
Raven855
01-21-2011 08:04 AM
06silvercrew
10-28-2008 10:19 PM
Quick Reply: Does a complete solution kit need a HPOP
