Positive engine block?
Old 02-11-2013, 09:04 AM
NodnarbDFD's Avatar
NodnarbDFD
NodnarbDFD is offline
So I've been having some electrical problems.
Hooked my power probe to the battery and had the whole fuse box removed, unplugged all the plugs and took the cable off. Also removed the PCM.
I'm getting 6.7V to a bunch of the wires. Also getting 6.7V to the engine block.
Does anyone know what might use 6.7 volts that could be shorting so I don't have to disconnect every plug and wire?
Old 02-11-2013, 01:43 PM
tomfiii's Avatar
tomfiii
tomfiii is offline
If something is leaking voltage and the ground is still hooked to block ,it sounds like a bad ground to block from battery which needs to be addressed first.
Old 02-11-2013, 07:27 PM
NodnarbDFD's Avatar
NodnarbDFD
I'm Sry Tom, I had the negative cable disconnected from the battery and the negative cable was putting out 6.7V also.
Am I doing things *** backwards trying to hunt down my electrical problem?
High_HP
10-30-2018 06:01 PM
hickory1991
21
06-02-2018 08:04 AM
rong63
18
02-22-2006 12:42 PM
r9wolves
Electrical Systems/Wiring
01-31-2005 10:37 AM
slntnddly
12-22-2003 06:40 PM
Quick Reply: Positive engine block?
