Problem with brakes and steering.
Old 02-02-2013, 12:12 AM
uuhiteboy's Avatar
uuhiteboy
uuhiteboy is offline
So i was out at my ranch and drove around a little out there. Nothing major done it 100 times before. So i come back to the ranch house for and hour or so and then im about to leave.
Once i started my truck i felt a pulse coming form the brake pedal and a whining noise. As i went to move i noticed there was a whine in the steering and slight vibration (nothing really more than normal). the steering whine and the brake problem got worse as u turned the wheel more and the harder you pressed. I then noticed that even if you pushed the brake pedal all the way down it would not stop quickly like it should. I drove it around a filed for a while and the brakes became better and the pulsing lessened.
I was told thats common for air in the lines. but its on the steering and brakes and i was not working on the truck or anything. Also i checked fluids and they where just below. I did fill them. another thing i noticed was you can see the vortex in the fluid if you look in the steering fluid reservoir while the truck is running.
You guys have had all the right answer so far please help a brother out.
Old 02-02-2013, 12:27 AM
BLADE35's Avatar
BLADE35
BLADE35 is offline
Souldnt be air inn lines it automatic bleeds air
Flush the HydroBoost System out
Old 02-02-2013, 02:48 AM
Yahiko's Avatar
Yahiko
Yahiko is offline
I agree with Benny.
The vortex in the fluid will pull air into the fluid and then through the pump
and give you that effect. When you flush out the system draw down the level in the
tank so that you can see the screen. I bet you will find a lot of crap on it. If you do
find crap you will need to seal off the lines and remove the tank and clean it out,
After that I would add the filter kit to the system for a few thousand miles to pick up
any more that may of gotten missed.
Then the question will be. What made the junk?
Sean
paul1016
10-25-2015 09:01 PM
tomthelegend
04-19-2014 02:31 PM
Big Sky
08-23-2012 02:14 PM
rb8612
07-23-2012 07:20 PM
sleek122
15
06-12-2010 11:48 AM
Quick Reply: Problem with brakes and steering.
