using double overdrives with a cummins
Old 01-29-2013, 02:25 PM
F350moneypit's Avatar
F350moneypit
F350moneypit is offline
I have been reading a lot of threads about cummins conversion and the subsequent gear changes people are doing to get the rpms down.
Has any one tried this combo:
cummins ->o/d tranny ->transfer case->gear vendors over drive unit?
as long as your not in four wheel drive with the O/D activated it seems like that could drop the rpms quite a bit.
Old 01-29-2013, 03:59 PM
co425's Avatar
co425
co425 is offline
Look at the specs of a gear vendor. I don't think it will live long with even stock cummins torque. A mild cummins can easily pump out 600 foot lbs. I think your are better off with a rear end ratio change with the nv4500 5 speed or nv5600 6 speed. Both tranny's are the same overdrive ratio.
Old 01-29-2013, 05:29 PM
lurch460's Avatar
lurch460
lurch460 is offline
I dunno bout that,I have seen some gearvenders go through hell on the dragstrip. I know there used to be two versions,one for higher hp and torque. I was at the SEMA show about 7 years ago and talked with gear vendors and I do recall them saying they had one available for diesels that made some serious power, but things might have changed since then. This is my plan if I ever get around to putting a cummins in.
Old 01-29-2013, 06:04 PM
1972RedNeck's Avatar
1972RedNeck
1972RedNeck is offline
If I had the money I would love to have 4.10's, a Getrag and a GearVendors in my Dodge. That would put the overall ratio at 2.33:1. Rigth now I have the 'rag and 3.07's, which puts me at 2.38:1.
Old 01-29-2013, 07:41 PM
F350moneypit
If I remember right most gear vendors units can handle 1500 hp but I don't know what torque values they're rated at.
Old 01-29-2013, 08:05 PM
co425's Avatar
co425
co425 is offline
I could be wrong but I seem to remember it only being around 400 ish ft lbs. The hp numbers were there just not the torque. Unless they now make a diesel unit.
Old 01-29-2013, 09:18 PM
Higbean's Avatar
Higbean
Higbean is offline
It seems to me every time I talk to a guy with a Gearvendor, they are bitching about blowing em up. They seem like a good idea, but for the price of one, you'd be close to putting in an Alison or a built 47RH. Heck, you could find a 6 speed 48RE with the two OD's for dang near the same price I bet.
Old 01-29-2013, 09:41 PM
1972RedNeck
Your still not getting the RPM's down.
sinister73
Ford vs The Competition
01-09-2015 05:07 PM
ghunt
11-01-2006 09:43 PM
Megalodon
123
01-31-2005 06:14 PM
Hiflyer746
01-17-2005 06:44 PM
tro54
05-16-2001 06:55 AM
Quick Reply: using double overdrives with a cummins
