transfer case gear ratio
Old Apr 24, 2001 | 07:52 PM
tro54's Avatar
tro54
Guys,
Please help an old man out. I could swear there's nothing about this in my 2000 Ford 4x4 owner's manual, or on the website.
What is the gear ratio in my 4x4-Lo setting in the transfer case (I was trying to calc my crawl ratio the other day). For instance, I know my 1st-gear gear ratio, I know my final axle ratio, aren't I missing another piece? If I'm not, then I've only got 410 lb feet of torque going down each separate drive shaft before it gets to the final gear ratio
Old Apr 25, 2001 | 09:24 AM
Chuck P.'s Avatar
Chuck P.
T-case should be in the 2.7(2.72?) to 1 range, give or take a little, sorry, not up on all the newer cases! To get your crawl ratio, this is expressed as tranny first x low range x rear gearing, example-3.00 to 1 first, 2.7 to 1 low, 4.10 to 1 rear, this would equal appx. 33.2 to 1 crawl ratio. For the torque, same thing, but plug in the torque of the engine, for example, 400 lb-ft(of peak torque) x first(3.00) x low(2.7) x rear(4.10) would equal appx. 13,285 lb-ft of torque going into the axles! More like the number your lookin' for? Hope this clears up things a little bit for you!
Old May 15, 2001 | 04:30 PM
mj's Avatar
mj
is that not listed on the data tag on the TC itself? if it is let us know what it was.
Old May 16, 2001 | 06:55 AM
TallPaul's Avatar
TallPaul
Daleksandrovich
Mar 22, 2014 09:37 AM
FastGilla
Apr 21, 2011 09:25 AM
97puller
Aug 28, 2010 06:59 AM
derherr65
Offroad & 4x4
Jul 7, 2006 12:40 AM
troy payne
18
Jun 29, 2004 10:54 PM
