Towing ?
Towing ?
I will be towing my TT up to Indiana in about 3 weeks and this will be the first time I've towed it with my DP tuner installed. It weighs in at 10k and I have the 80 tow, 60 tow and the 40 tow on my tuner. Should I leave it in overdrive and in 60 tow or should I take it out of overdrive and in 60 tow? Going through the smokey mountains will be the biggest headach. I have gauges and the 6.0 cooler so im not to worried there.
Yes I did know that but I was just wondering on where to start off from. So I guess I start off in overdrive and 60 tow see how it drives. I plan on driving between 60 & 65 mph. Thanks for the input.
One my way down to Fl from the Smokies I pulled the long steep climbs in 40T and my EGT's were spot on. When I got to the small hills and rolling country I ran in 60T. But when I got into the flatland of Fl I tried running in 80E . I kept close watch on my gauge and she ran awesome ! Hardly knew that 34 ft fiver was on . Have a safe trip !
Smokie
Smokie
2 years old ! You up in my area !! Does the 80T have the hard shift program like the 40 and 60T ?
Smokie
Maybe we can GTG sometime in the spring in Pigon Forge..We like to stay at the KOA there
Rob, you should be fine in 60Tow, and be able to use OD without much downshifting until you get into the bigger hills of the Smokies. Just keep an eye on EGT and listen for turbo surge. If either one of those become problematic, turn OD off and let the ol' girl wake up in the higher rpm's. Try to get a little momentum on the downhills if you can, the uphills will bring your speed down to 45-50mph most likely. If you can get the turbo spooled up prior to starting a climb, it will be easier to keep the boost up while pulling the hill. Have fun, you're going to see what these trucks are made for!
Hey Rob, I'm running php, not DP, but I throw it in 60 tow and walk the dog. Boost will run up to 11-14 lbs and as long as I hit the hill above 65, there's now downshifting needed. Keep an ear and eye out for surge and egt though. I start getting a little surge between 10-12.
I'm going to get a reburn and add 80 tow to see what it does. It definitely will feel better 65 and up than it will at 55-60, so don't hesitate to try out a few different speeds to see what feels best with your setup.
Good luck and be safe
no, I have no hard shifting,but I am live tuned and it shifts the way I like, firm but not hard and I like the down shifting.With 2 year old tunes,I would get with Jody and update them..
My tunes are only 4 months old also. Glad to hear you didnt have any issues going through the smokies, that leaves me feeling alot better.
