94 slave cylinder replacment.
Old 01-23-2013, 03:44 PM
ramick's Avatar
ramick
ramick is offline
I went to start my truck yesterday and I didn't have any clutch pedal. It had been very cold and by cold I mean 2 degrees. I thought it might be frozen so I let the truck idle for 30 minutes and nothing happened. So then I put it in the garage and put a salamander under the truck to thaw it out, after 30 minutes of that it still wasn't working. I did some research and found it was most likely my slave cylinder. I guess my question is are there any things I need to know or special tools that will help me along, thanks.
Old 01-23-2013, 03:59 PM
88n94's Avatar
88n94
88n94 is offline
Model of truck, engine and transmission?
Old 01-23-2013, 04:07 PM
ramick's Avatar
ramick
ramick is offline
Sorry. 1994, F150, 4.9L, Its a 5 speed but I do not know the exact model of transmission.
Old 01-23-2013, 04:22 PM
88n94's Avatar
88n94
88n94 is offline
You may know this requires the removal of the transmission. I would make sure the slave cylinder is blown first. Have you checked the fluid level in the clutch master cylinder? Don't forget to remove the rubber cup under the cap. Add only dot 3 brake fluid.
Old 01-23-2013, 04:47 PM
ramick's Avatar
ramick
ramick is offline
I am prepared to drop the transmission, I did check the fluid level and it was good but I did not know there was a cup in the reservoir, will check that.
collkid
04-23-2019 04:37 PM
Gunnerboy
03-26-2016 07:12 AM
DanielT28
11-01-2012 09:13 PM
duckshepherd
1983 - 2012 Ranger & B-Series
03-19-2011 02:01 AM
1988F-150
03-13-2010 10:47 PM
Quick Reply: 94 slave cylinder replacment.
