Slave cylinder question.
Old Mar 13, 2010 | 12:31 AM
1988F-150's Avatar
1988F-150
Okay, so I've been trying to bleed my clutch for a while. But the darn thing just won't do it. So, I think I might have been sold a bum slave cylinder. So, how can I tell if it's the slave cylinder without tearing the transmission out again. Oh, its the Mazda transmission if you need to know that.
Old Mar 13, 2010 | 12:42 AM
88n94's Avatar
88n94
Generally when the slave cylinder is bad, all the fluid will go out of the master cylinder through the slave cylinder. Have you tried gravity bleeding it?
Old Mar 13, 2010 | 02:42 AM
88n94's Avatar
88n94
You are removing the rubber cup(diaphram) that sits under the master cyllinder cap before adding brake fluid to the clutch master cylinder? Just a thought.
Old Mar 13, 2010 | 04:27 AM
Lazy K's Avatar
Lazy K
Bleeding a Concentric Hydraulic Clutch Set-up .: Articles Have a read here. Parts of it may help.
Old Mar 13, 2010 | 10:47 PM
1988F-150's Avatar
1988F-150
Actually, that does help. Because he said to NOT pump it and thats what I've been doing. And yes, I've tried gravity bleeding it, but the way its sitting it's either taking longer or not letting it do it right. And yes, I removed the cup. XP
