Slave cylinder help
Old Mar 24, 2016 | 04:35 PM
Gunnerboy's Avatar
Gunnerboy
Slave cylinder help
So just had the slave cylinder go out.. im assuming being the clutch pedal went to the floor while driving and i had brake fluid everywhere... these trucks are heavy to push.. But anyways Its a 93 f150 5.0 5spd.. I have never replaced one of these before so anyone have a great write up or tutorial on what to do?
Old Mar 24, 2016 | 06:13 PM
seagiant's Avatar
seagiant
Hi,
Google and U-Tube is your friend!!!
I just replaced my Clutch master cylinder!
There's nothing that says it HAS to be the slave unless it's leaking from there!
My master bled on my clutch safety switch, had to change that also!!!
Old Mar 24, 2016 | 08:44 PM
Willz74's Avatar
Willz74
Pull the transmission back about 6 inches pull it out put the new one in it takes a 10 mm I would suggest napa over Oreillys the clip is a pain on the Oreillys and came apart on me in Denver 11 mm for the bleeder screw
Old Mar 25, 2016 | 01:50 AM
SKOALBANDIT88's Avatar
SKOALBANDIT88
From my experience if you're gonna change the slave cylinder you might as well change the clutch master cylinder too. Especially if they both have the same amount of age on them.
Old Mar 25, 2016 | 07:41 AM
madpogue's Avatar
madpogue
FIRST, narrow down whether it's the slave, the master or the line. All my trucks are external slave, so I apply the above advice and replace with a complete pre-bled master-line-slave kit. But presuming yours is an internal slave, that's a lot more work; I'd be tempted to swap just the master if that's what's determined to be leaking.
Old Mar 25, 2016 | 10:14 AM
Gunnerboy's Avatar
Gunnerboy
This appears to be a internal slave.. so should i go ahead and change the master while im down tearing everything apart? the clutch was replaced 36k ago but i got the truck 5k ago.. SO looking over reciepts looks like neither the master or slave was replaced when the clutch was.
Old Mar 25, 2016 | 12:49 PM
78 PEB's Avatar
78 PEB
I would replace both, just because you don't know when or if they ever have been replaced. They aren't that expensive and just a bit of added insurance.
Old Mar 25, 2016 | 08:53 PM
Gunnerboy's Avatar
Gunnerboy
So i went ahead and replaced the Master clutch cylinder.. alot easier job than i expected and got the driveline unhooked and starter off and shifter off... So in my twisted mind im thinking if i put a floor jack under the transfer case and one under the transmission i could scoot the whole thing down about 8" to unbolt and re bolt the Slave cylinder.. does this plan sound feasible?
Old Mar 25, 2016 | 11:13 PM
Willz74's Avatar
Willz74
That's how I always did it the transmission needs spun a bit because of the gas tank
Old Mar 26, 2016 | 07:12 AM
Nothing Special's Avatar
Nothing Special
Just be careful that it doesn't fall off the jacks, especially if you're under it. A trans / t.case assembly is big and awkward and not the easiest to balance.
One thing I've done on my '71 Bronco a few times is leave the trans bolted to the crossmember but unbolted the crossmember from the frame. Then I C-clamped some 2x4s to the frame rails for the crossmember to sit on . That way I could move the whole thing back with no risk of it tipping or dropping. I don't know if anything like that will work with your truck, but it's an idea to have in mind.
collkid
Apr 23, 2019 04:37 PM
89nolaf250
Jan 31, 2010 01:37 PM
1179
Aug 31, 2006 07:03 PM
vandm
Aug 21, 2006 11:42 PM
DT 466Man
Jun 28, 2005 09:11 AM
