Need ideas on brake drum hub woes
I am working on rebuilding my 52 F-3 suspension with plans on upgrading the front brakes to the 8 bolt lug disk brake kit that is available through Street rod maunfacturing....Problem is the hub is rusted to the drum, I have been soaking it with PB blaster but doubt that I can get the three mounting screws loose with my hand impact driver. Anybody have ideas on how to get these apart? btw, the hub/drum is sitting on the bench as I have dis-assembled the front end (actually the whole truck is down to the frame)
Thanks for the input,
w
w
If I read this correctly the screws are frozen? If that is the case take a torch (propane/ map may work) and heat the screw until it is glowing red and remove. Once they are removed, if the drum still doesn't come off try heating where the hub comes thru the drum ( on the drum).
Good Luck,
Paul
Good Luck,
Paul
Doc wrote the correct procedure on this:
https://www.ford-trucks.com/forums/1...l#post10920202
Drill the screws out first
Thanks
W
bmoran4
05-11-2013 06:35 AM
