Need Tips on Horsepower..
Old 01-20-2013, 09:36 PM
1988F250Beast!!'s Avatar
1988F250Beast!!
1988F250Beast!! is offline
Hey, i'm new to the forum but thought i'd give her a shot.. I have a 1988 F250 she has a 460 with MFI fuel injection backed up by a 5 speed manual. i want any tips on what i can do to add Horsepower and performance as much as possible for a decent price under 1,000 but can go u p to 2,000 thanks so much!
Old 01-20-2013, 10:32 PM
OldGrayFord's Avatar
OldGrayFord
OldGrayFord is offline
Here are a couple things you can do. Remove silencer restrictions in air intake tubes, insulate air box and intake tubes to make a cold air system, headers, good flowing exhaust(either two into large diameter one,or dual with crossover. Google project mpg, it's a write up Peterson 4wd did several years ago. It has good tips for both power and mpg. I know someone who ported his heads and swapped to a ford Motorsport cam. He told me its discontinued but that you can still get it from crane. He was very happy with the results. A good tuneup and bumping the timing up a bit helps too
Old 01-20-2013, 10:49 PM
1988F250Beast!!
Thanks! I've been working on the exhaust, i' going to take the cat out within a week or so i have a flowmaster on it for a muffler now tho.. an i'll work on it this weekend an try a few of those. it's just such a big engine with measly hp it's sad needs to be boosted a good amount.. if you know of any other good plases please let me know. thanks!
Old 01-20-2013, 11:22 PM
OldGrayFord
I put dual 2.5 inch exhaust with crossover pipe and dual flowmasters all run down the passenger side(basically the stock location) no cat. Pretty noticeable difference for me. It's my experience that these engines are set up for pretty low rpm torque so looking to maximize its strengths are best. If I were doing exhaust again idmdo headers at that time. Do a forum search for headers. There are some guys who found headmans fit with the 5 sp even though the fit guide said otherwise. Definitely check out the article I mentioned. The also used a hyper tech product, I'm not sure if it would still be available. I changed my distributor out recently to fix a problem with the pickup inside and I'm pretty sure I found power I didn't know I was missing. Go to the big block385 part of the forum and search six liter tuneup , it refers to a guys username . Good info on a good tuneup befor trying a little more timing. Don't go too far I dont think our 460's like too much especially with ethanol gas
Old 01-21-2013, 02:50 AM
1988F250Beast!!
Ok, thanks so much for all of your help! I found a nice set of headman headers I think I'm going to get for it and i'll check out the other forum in the morning. I know I need to replace my distribuitor but not sure on the one to get. Mine is the one that came with the truck 100, 600 miles ago.. I looked at msd but they would eat up near all my budget is there a good happy medium from stock to those?
Old 01-21-2013, 07:20 AM
fdude64's Avatar
fdude64
fdude64 is offline
I can say from experience don't get a richporter tech distributor. I got a new one this weekend and it took a crap in the first 1/4 mile. I ended up with a reman and it had a new pip in it. haven't driven it yet but response seems greatly improved from revving it up in the garage lol.
Old 01-21-2013, 11:28 AM
OldGrayFord
If you search this forum for 7.5 headers there was quite a discussion on what fits. That's pretty low miles for a truck that age. I've been told the cam I mentioned earlier was quite an improvement too. Good luck with your mods. Keep us posted as to results
Old 01-21-2013, 12:39 PM
1988F250Beast!!
Ok thanks i'll take a look at it. And ya the guy I bought if from had it since new he was a older guy hardly used it. An i'll try the cam to i'll see if I can find one first. I'll keep you posted! Thanks for all your help!
Old 01-21-2013, 01:01 PM
1988F250Beast!!
Thanks! I'll look into some different ones I want one that improves it more than what I have. I was talking to a guy that drag races yesterdaya he said you want an ignition that gives a good healthy spark I want to find something good for around 2-300 if possible
coryv4
17
06-19-2013 10:23 PM
caseymou
09-09-2010 02:05 PM
roostercrows
1978 - 1996 Big Bronco
06-13-2007 07:13 PM
klp
Exhaust Systems
24
01-26-2004 07:29 AM
K_Burne
Exhaust Systems
02-04-2002 03:31 PM
Quick Reply: Need Tips on Horsepower..
