Coolant burn-off issues......
My '97 F250 5.4L is pumping coolant on to the top of the motor which is burning off causing it to smoke like it's overheated but the temp gauge is operating in normal range. I'm losing coolant but can't see where. It's not going to the ground. It just pools up on the top of the motor. I've already replaced the water pump in the last 2 weeks because of the same issue. It stopped for a few days but now it's back again. Bad water pump from O'Reily's or is there some other issue here? I've checked while the motor's running and can't see where the coolant is coming from and there's no coolant coming out of the bleed hole in the top of the new water pump. I need this truck up and running. Anyone have any ideas??? Please help!!!
I found the leak. It's coming out of the intake gasket on the front passengers side of the motor. Does this mean I need to get a whole gasket kit and rip apart the whole top of the motor to redo the intake gaskets? Not looking forward to this since I don't have a garage and it's freezing outside........
The intake manifoldl is plastic. The cross over tube bolted to the bottom of the intake is made of aluminum. It does not have gaskets, it has an 0-ring groove in the plastic. If the manifold gets overheated, or possibly just due to old age, the o-ring grove craps out and the o-ring will blow out and cause the leak. You will need a new manifold, or fill the groove with epoxy, smooth it flat and seal with a gasket. Dont worry about being an "old time mechanic".. im in the same boat. Its not much different than pulling a manifold off a 1970 351V8... jut a few more small parts like the injection fuel rails, etc... While your in there, its a good time to look at the spark plugs.
https://www.ford-trucks.com/forums/8...d-on-5-4l.html
