Need HELP with my 1993 F150
I have a 1993 f150 with the 302, auto tranny 4wd etc, the thing I need help with is when I first got the truck it sat for a year or two, I would start it up and it would idle then immediately shut off. then I took the mass air flow sensor out and cleaned the crap out of it, then it would idle, while I've restored it, it sat inside a garage for 6 months, now the problem is not that it won't idle, but instead it starts right up and idles low, then when I shift into drive or reverse it idles down and sometimes even shuts off. it had some bad gas in it, do I have a serious issue or does anyone think just a new tank of gas some seafoam and a long drive will help it? PLEASE HELP
on
Regarding your low idle & failure to adjust when put in gear. Sounds IAC related. Many times removal/ clean/ reinstall will do the trick. Just takes a few minutes & i've yet to have to replace the gasket when I've done it.
See Link: Fuel Injection Technical Library » Idle Air Bypass (IAB)
pumped out most of the old gas from the front tank, it was a heavy yellow color and had that old gas stench to it, need to replace the filter and add new gas, anyone have any other suggestions for my issue? also running a check engine light and sometimes it flickers.. i cant read the codes so anyone think it could be from sitting and running hard? help
on
Did you look into this?
estearly
10-03-2004 11:28 PM
SpunkyKitten
02-02-2003 03:38 PM
