1988 f150 problems
Old May 31, 2004 | 03:43 PM
jonnysteals's Avatar
jonnysteals
1988 f150 problems
I got a 1988 F-150 4x4 with 302 for free with 255,000 miles and was still running strong. I let it sit fro a while and now my truck idle all crazy. Some daysa it will be fine and other days it will stall out unless i give it gass. My second problem is my gas gauge dont work. It wouldnt be such a problem but my truck ddont have a tripometer so i got to rember when to put gas it it, its a pain in the butt. It works when its form a quater to empty though any suggestions.
Old May 31, 2004 | 04:04 PM
Fully_Loaded's Avatar
Fully_Loaded
My float for the sending unit had a hole in it and caused it to fill with gas trapping a small air bubble and it did the same thing. I put a little of that gas tank repair on it and it is good as new. As far as the idle I would check out your idle air sensor on the side of the throttle body. This controls your idle speed. (I am assuming it is fuel injected being an 88) I hope this can help.
Old Jun 1, 2004 | 12:27 PM
jonnysteals
How did you go abotu taking the float off do you have to take the entire gastank off or can it be accesed some other way. Jon
Old Jun 1, 2004 | 04:40 PM
Fully_Loaded
You have to drop the tank and pull the pump out you will see the float. This is one possiable prob though I would exhaust all other options before dropping the tank. It is never any fun.
