pulsating brake pedal
Old 03-05-2013, 09:06 AM
mikren's Avatar
mikren
mikren is offline
when braking i would feel the pedal pulsating...figured the pads were finished. checked them out and they were not in that great a shape so i changed them all around. I'm still getting a pulsating feeling in the brake pedal....u guys think i just need to bleed them or are the discs warn or warped or something ? thanks
mike
Old 03-05-2013, 10:17 AM
shooter123's Avatar
shooter123
shooter123 is offline
warped rotors. have them turned or replace them.
Old 03-05-2013, 11:54 AM
Bluegrass 7's Avatar
Bluegrass 7
Bluegrass 7 is offline
New rotors and pad do wonders for brake feel.
The hint of the day is 'do not' over tighten the front discs.
It can put a wavey distortion in them that will be temperature sensitive and drive you nuts wondering what's going on, at different times.
If left like that long enough , the discs won't recover from a wear pattern by retorqueing.
Good luck.
Old 03-05-2013, 11:58 AM
Papa Tiger's Avatar
Papa Tiger
Papa Tiger is offline
Temporarily Deactivated
Received 3,432 Likes on 2,347 Posts
Probably a stuck piston in the caliper also. Everything U ever heard bad about disc brakes is started with sticky caliper pistons. These are usually brought about by a hole to the boot seal. When U got a truck 10 years old, 100,000 miles, save UR selves a lot of grief.
Old 03-05-2013, 12:41 PM
mikren's Avatar
mikren
mikren is offline
ok thanks.... how could one over tighten front discs ??? do you mean caliper ? or am i not getting something ?
Old 03-05-2013, 12:57 PM
RebColonel's Avatar
RebColonel
RebColonel is offline
He means over torqueing the wheel lug bolts. If your brake pedal is pulsating do what Shooter said and turn or replace the rotors.
Old 03-05-2013, 02:18 PM
mikren's Avatar
mikren
mikren is offline
thanks , will do. yeah lug nuts are to specs. Thanks again
Old 03-06-2013, 03:08 PM
1Aauto's Avatar
1Aauto
1Aauto is offline
Former Vendor
HI Mike, we have some great prices on rotors if you need them. Here's a link to them on our website if you want to see what we have. Tony
F150 Brake Rotors
Old 03-07-2013, 07:08 AM
R Pope's Avatar
R Pope
R Pope is offline
I broke two studs off getting a tire off my truck, with the spare on I had a bad vibe getting to town to get a few new studs. Went away when i replaced them.
BTW. the pricing on studs is variable. Ford sold me the only one in stock for 6 bucks, the Parts Source store nailed me for 23 fun tickets! WTF?
Wolverine72
03-26-2011 08:38 AM
madpogue
09-26-2009 07:43 AM
Braker 19
1997 - 2003 F150
03-17-2007 10:01 AM
ACE81
07-17-2005 12:51 AM
evan250
06-21-2005 11:52 AM
Quick Reply: pulsating brake pedal
