New to the site this is my first post and I picked up my F250 two days ago. Sync only allows me to play my music off my iPhone 5 if I have it connected with the usb. Is this the normal operation or is there a way to play music from my iPhone 5 with it bluetoothed because it currently won't let me. My friend has a 2011 F150 with an iPhone 5 and he bluetooths his music through sync. Can someone please enlighten me on this issue. Thank you very much.
I don't have an iPhone, but on my Android phone, I have to select to "enable media" through bluetooth. I can only do this while the phone is connected to Sync, otherwise the option is greyed out.
I figured out how to get it to work but I have to scroll through and turn it on every time. I just want it to work when I switch to sync without having to scroll through everything
If your phone isn't pairing or autoconnecting try this with the truck off:
1. On the iphone that you want to auto connect, do a "FORGET THIS DEVICE" in the SETTINGS>BLUETOOTH function for the Stereo (tap the ">")
2. Turn BLUETOOTH OFF in SETTINGS>BLUETOOTH on the iOS device
3. TURN THE KEY TO ON OR START THE TRUCK
4. Turn BLUETOOTH ON in SETTINGS>BLUETOOTH on the iOS device
5.Go to SETTINGS>BLUETOOTH on the iOS device and PAIR to the Dashboss
