Sponsored by: Real Truck
GLOW PLUGS NOT WORKING
Old Dec 23, 2012 | 11:12 AM
oldesalt's Avatar
oldesalt
F-350, 2003, 6.0 diesel. Just rebuilt top end (head gasket, ARP studs, upgraded EGR). Glow plugs not working. Dash glowplug light comes on cold and almost immediately goes out. Checked all plugs and they seem to be connected O.K. ???????
Old Dec 23, 2012 | 04:24 PM
Yahiko's Avatar
Yahiko
Check the engine battery cable ground points. Remove and clean then
to start with.
After that come over here and ask you questions and you will get a bunch of help
6.0L Power Stroke Diesel - Ford Truck Enthusiasts Forums
Sean
Old Dec 23, 2012 | 10:29 PM
oldesalt's Avatar
oldesalt
GLOW PLUGS NOT WORKING, 03 6.0 DIESEL
Thanks. We're pretty sure all of the grounds are ok, especially since the FICM, which is very voltage-sensitive, seems to running the engine just fine. Most of the grounds were cleaned and anti-corrosion applied before we put the cab back on.
riggers
22
Feb 12, 2012 07:16 PM
trakman
Jan 31, 2011 09:23 PM
gummybear918714
Apr 20, 2010 09:59 PM
xcnick38
Mar 13, 2008 07:51 AM
idifamilycab
Apr 29, 2007 12:13 PM
