edelbrock compatability headache
ok so i have called compcams and edelbrock and they wont give me a clear answer to my question. so im going to ask you guys. i am ordering Edelbrock Performer RPM Cylinder Heads 60058, they are bare, i have High Energy™, 268H: Cam & Kit for my my motor. i want to use this rocker assembly COMP Cams Ford FE Shaft Rockers 1046-KIT. my question is will this bolt to these heads and work with my cam. will stock rocker stands work? are my springs to small or big? please let me know.
Made from 7000 Series aluminum, these 1.200 in. wide rocker bodies from COMP Cams are recommended for engines using roller camshafts. These shaft systems are equipped with special end stands for valvetrain stability at high rpm, and therefore virtually eliminate shaft failure. The systems also feature top and bottom oil holes for added rocker lubrication.
pretty sure they come with their own stands
ford1967
10-12-2017 01:14 PM
ColodadoFordBoys
01-20-2009 08:46 AM
Randyb12
09-14-2003 10:01 PM
