Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
2012 escape door code?
Old 12-06-2012, 07:36 PM
Curt's05's Avatar
Curt's05
Curt's05 is offline
Wiser by FTE
Does anybody know if i can add a door keyless entry code, in addition to the master code? The manual does't mention
this i possible. Thanks in advance, Curt
Old 12-06-2012, 07:41 PM
Archion's Avatar
Archion
Archion is offline
It's called a search. I can think of at least 3 maybe 4 threads in the past month or so. Try page 2.
Old 12-07-2012, 07:42 AM
wptski's Avatar
wptski
wptski is offline
It should, it was in my owner's manual. I think that you just enter the master five digit code then the five digits that you want.
Old 12-08-2012, 06:17 AM
ccecilm2's Avatar
ccecilm2
ccecilm2 is offline
From my 2010 owner manual:
Programming your own personal entry code
To create your own personal entry code:
1. Enter the factory set code.
2. Within five seconds press the 1
2 on the keypad. The doors will lock and then unlock to confirm that the system is in programming mode.
3. Enter your personal 5–digit code. Each number must be entered
within five seconds of each other.
4. Press 1
2 on the keypad to assign the Driver 1 setting. The
doors will lock and then unlock to confirm that your personal entry code
has been programmed.
You can store up to three personal entry codes. The above procedure
shows how to set the Driver 1 setting. To assign the additional settings, repeat Steps 1 through 3, then for Step 4, do one of the following:
Press 3 4 to assign the Driver 2 setting.
Press 5 6, 7 8, or 9 0 to assign the Driver 3 setting.
Tips
Do not use five numbers in sequential order.
The factory set code will work even if you have set your own personal
code.
Erasing personal code
1. Enter the factory set 5–digit code.
2. Within five seconds, press the 1
2 on the keypad and release.
3. Press and hold the 1
2 for two seconds. This must be done within
five seconds of completing Step 2.
Your personal code is now erased and only the factory set 5–digit code
will work.
Old 12-09-2012, 07:37 PM
Curt's05's Avatar
Curt's05
Curt's05 is offline
Wiser by FTE
4. Press 1
Tips
code.
will work.
Awesome your post worked! Thank You, Curt
robert_l_ross
02-18-2021 10:37 AM
scotterd
07-27-2015 06:43 PM
86paGT
12-28-2008 10:40 AM
Harrski
2004 - 2008 F150
13
06-11-2006 05:56 PM
lariatf150
2004 - 2008 F150
03-29-2004 03:29 AM
Quick Reply: 2012 escape door code?
