Does anybody know if i can add a door keyless entry code, in addition to the master code? The manual does't mention
this i possible. Thanks in advance, Curt
Reason: add line
It should, it was in my owner's manual. I think that you just enter the master five digit code then the five digits that you want.
To create your own personal entry code:
1. Enter the factory set code.
2. Within five seconds press the 1 • 2 on the keypad. The doors will lock and then unlock to confirm that the system is in programming mode.
3. Enter your personal 5–digit code. Each number must be entered
within five seconds of each other.
4. Press 1 • 2 on the keypad to assign the Driver 1 setting. The
doors will lock and then unlock to confirm that your personal entry code
has been programmed.
You can store up to three personal entry codes. The above procedure
shows how to set the Driver 1 setting. To assign the additional settings, repeat Steps 1 through 3, then for Step 4, do one of the following:
Press 3 • 4 to assign the Driver 2 setting.
Press 5 • 6, 7 • 8, or 9 • 0 to assign the Driver 3 setting.
Tips
Do not use five numbers in sequential order.
The factory set code will work even if you have set your own personal
code.
Erasing personal code
1. Enter the factory set 5–digit code.
2. Within five seconds, press the 1
• 2 on the keypad and release.
3. Press and hold the 1 • 2 for two seconds. This must be done within
five seconds of completing Step 2.
Your personal code is now erased and only the factory set 5–digit code
To create your own personal entry code: 1. Enter the factory set code.
3. Enter your personal 5–digit code. Each number must be entered within five seconds of each other. 4. Press 1
doors will lock and then unlock to confirm that your personal entry code has been programmed. You can store up to three personal entry codes. The above procedure shows how to set the Driver 1 setting. To assign the additional settings, repeat Steps 1 through 3, then for Step 4, do one of the following:
Tips •
code.
Erasing personal code 1. Enter the factory set 5–digit code. 2. Within five seconds, press the 1
five seconds of completing Step 2. Your personal code is now erased and only the factory set 5–digit code
