Door Code - Owner's Manual Correction
Old Mar 25, 2004 | 05:31 PM
lariatf150's Avatar
lariatf150
For those of you with keyless entry system (the door keypad):
The onwer's manual is wrong. Wrong in how you clear/erase a personal entry code. This is a code you enter into the system to use instead of the factory code (but the factory code will remain valid for use as well). I wanted to erase my personal code but it wouldn't work the way the book said to do it. I asked my salesman (1956MarkII) about this and he set me (and Ford) straight.
Here's what the manual says:
Programming a personal entry code
To create your own personal entry code:
1. Enter the factory set code (keypad will illuminate when pressed).
2. Within five seconds press the 1 • 2 on the keypad.
3. Enter your personal 5-digit code. Each number must be entered
within five seconds of each other.
4. After the code is entered, the locks will cycle, confirming that the new
code has been set.
Tips:
• Do not set a code that uses five of the same number.
• Do not use five numbers in sequential order.
• The factory set code will work even if you have set your own personal
code.
• If you set a second personal code it will erase your first personal code.
Erasing personal code
1. Enter the factory set 5–digit code.
2. Press and hold the 1 • 2 for two seconds. This must be done within
five seconds of completing step 1.
Your personal code is now erased and only the factory set 5–digit code
will work.
Regarding erasing the code, here's what the book SHOULD say:
2. Press and release the 1 • 2. This must be done within
3. Press and HOLD 1 • 2 for 30 seconds.
Note for step 3: You will not hear the locks cycle after holding 1 • 2 for 30 seconds, but the process IS complete after 30 seconds.
will work.
Old Mar 25, 2004 | 05:54 PM
Mudlord's Avatar
Mudlord
That's good info to have. Thanks.
Old Mar 25, 2004 | 09:47 PM
Sully04 F150 4x4's Avatar
Sully04 F150 4x4
Is the factory code in the manual somewhere? How do I find out what the factory code is?
Thanks in advance.
Old Mar 25, 2004 | 11:49 PM
edmundrsku's Avatar
edmundrsku
My factory code was on a small card in the black owner's manual/warranty case.
Old Mar 28, 2004 | 02:20 PM
4XXF983's Avatar
4XXF983
Red face Keyless entry pad question
I have a 2000 Ford Explorer that I purchased from an "other than Ford" dealer, it has a keyless entry pad but I don't have the factory code or the original owners manual. Is the code located some where in or on the vehicle? Any help is appreciated
Old Mar 28, 2004 | 03:01 PM
1956MarkII's Avatar
1956MarkII
Go to the Explorer forum and read the "sticky" post near the top of the page. There are several pages devoted to this topic!
Old Mar 28, 2004 | 03:50 PM
4XXF983's Avatar
4XXF983
Thumbs up Thank You!!!!!!!!
Just through your referring me to the other forum you saved me quite a bit of money & time! Thanks for helping out a newbie to the site.
Old Mar 28, 2004 | 04:31 PM
1956MarkII's Avatar
1956MarkII
You're under the impression that my services are FREE?! Newbies...
Seriously, glad we could help. Don't be a stranger!
Old Mar 29, 2004 | 12:47 AM
ATCS2004's Avatar
ATCS2004
Factory Code
Thanks in advance.
When I picked my truck up the card was not in the Owners Manual. I had to have the dealership pull the code out of the computer on the truck. It took about 30 minutes.
Old Mar 29, 2004 | 03:29 AM
grayflare's Avatar
grayflare
For future reference, The factory set code is located on the body computer. On the 04 F150 Scab its behind the rear seat back on the drivers side.
