2012 escape door code?
Does anybody know if i can add a door keyless entry code, in addition to the master code? The manual does't mention
this i possible. Thanks in advance, Curt |
It's called a search. I can think of at least 3 maybe 4 threads in the past month or so. Try page 2.
Originally Posted by Curt's05
(Post 12567503)
From my 2010 owner manual: Programming your own personal entry code To create your own personal entry code: 1. Enter the factory set code. 2. Within five seconds press the 1 • 2 on the keypad. The doors will lock and then unlock to confirm that the system is in programming mode. 3. Enter your personal 5–digit code. Each number must be entered within five seconds of each other. 4. Press 1 • 2 on the keypad to assign the Driver 1 setting. The doors will lock and then unlock to confirm that your personal entry code has been programmed. You can store up to three personal entry codes. The above procedure shows how to set the Driver 1 setting. To assign the additional settings, repeat Steps 1 through 3, then for Step 4, do one of the following: • Press 3 • 4 to assign the Driver 2 setting. • Press 5 • 6, 7 • 8, or 9 • 0 to assign the Driver 3 setting. Tips • Do not use five numbers in sequential order. • The factory set code will work even if you have set your own personal code. Erasing personal code 1. Enter the factory set 5–digit code. 2. Within five seconds, press the 1 • 2 on the keypad and release. 3. Press and hold the 1 • 2 for two seconds. This must be done within five seconds of completing Step 2. Your personal code is now erased and only the factory set 5–digit code will work. |
Originally Posted by ccecilm2
(Post 12572583)
From my 2010 owner manual: Programming your own personal entry code To create your own personal entry code: 1. Enter the factory set code. 2. Within five seconds press the 1 • 2 on the keypad. The doors will lock and then unlock to confirm that the system is in programming mode. 3. Enter your personal 5–digit code. Each number must be entered within five seconds of each other. 4. Press 1 • 2 on the keypad to assign the Driver 1 setting. The doors will lock and then unlock to confirm that your personal entry code has been programmed. You can store up to three personal entry codes. The above procedure shows how to set the Driver 1 setting. To assign the additional settings, repeat Steps 1 through 3, then for Step 4, do one of the following: • Press 3 • 4 to assign the Driver 2 setting. • Press 5 • 6, 7 • 8, or 9 • 0 to assign the Driver 3 setting. Tips • Do not use five numbers in sequential order. • The factory set code will work even if you have set your own personal code. Erasing personal code 1. Enter the factory set 5–digit code. 2. Within five seconds, press the 1 • 2 on the keypad and release. 3. Press and hold the 1 • 2 for two seconds. This must be done within five seconds of completing Step 2. will work.Your personal code is now erased and only the factory set 5–digit code Awesome your post worked! Thank You, Curt |
