degas bottle dirty??
I dont know for sure if my truck had greasy film in degas before repair but it does now. last thing done was faulty injector had diesel mixing with oil. my oil cooler was replaced about 1800 miles ago after engine failure. I have diesel green coolant but dont remember the mess in the degass before.
Color isn't the best indicator Bud. My ELC is yellow - looks like the Gold stuff. Also, if the Ford add pack is added in w/ the Gold, it will turn the coolant a green color (hopefully the OP's case).
Bud has you covered on advice. Clean it out and get a fresh charge of the proper coolant. I would also be watching the degas bottle pressures.
Have you ever had any "puking" of the coolant?
Greasy coolant isn't necessarily oil contamination. Oil will emulsify quickly and turn into a tan or brown sludge.
So 1800 miles since an oil cooler. Shouldn't that mean that the current coolant charge is fresh also? Who did the oil cooler job?
