p0420 and p1401 codes
Code p0420: Catalyst System Efficiency Below Threshold (Bank 1) indicates that the readings received by the THIRD O2 sensor (downstream of the catalytic converter) showed less oxygen than acceptable. The short answer is that the catalytic converter is failing either because it is clogged or the substrate has deteriorated to a point where the unit is simply not functioning well enough.
Code p1401: indicates that the voltage received from the EVP (EGR Valve Position) sensor was higher than expected. This means that the EVP sensor is allowing more voltage than it should back to the computer. The short answer is that the sensor should be replaced. It is mounted atop the EGR valve on the passenger side of the engine. It has a 3-wire connector.
To troubleshoot the EVP sensor, apply vacuum to the valve manually and release it slowly. You should be able to connect a meter to the center and left-hand pin of the sensor and (with the meter set to read resistance) watch it slowly decrease resistance as the vacuum is released. However, even with no vacuum applied, there should still be some resistance. The meter should never drop to zero.
thanks for the info greystreak.
thanks for all the help
If the truck starts and runs clear all codes and run the test again. p0320 is an ignition fault Code that triggers under initial startup misfire conditions. Basically means that there was a misfire at some point since the last time Code memory was cleared. If the truck runs fine and idles properly, you shouldn't need to worry about it.
court1100f
09-11-2010 05:52 PM
