cigarette lighter problems
Old 10-07-2012, 02:13 PM
lookthepart's Avatar
lookthepart
lookthepart is offline
hello:
just got a 2003 e250 club van. it has the cigarette lighter socket as well as the data socket.
the cigarette lighter works in its socket but nothing else will. the data , nothing.
changed the fuse , checked the wire ,cleaned the sockets.
any info on a fix??
thanks in advance
Old 10-07-2012, 05:32 PM
joshofalltrades's Avatar
joshofalltrades
joshofalltrades is offline
i know in the older body style, the wire powering the cig lighter port was short enough that it usually came unplugged whenever the panel was removed. i don't know if thats an issue in the newer vans.
what you should do is test to see if the contact in the center has power AND if the outer body of the socket is grounded. a simple test light can do this for you. from there, a problem on power getting to it can be bypassed with a new wire going through a fuse to the battery or distribution block. if its a ground problem, just run a new wire from the ground side of the socket to a good clean piece of steel thats grounded.
if both seem to be connected, your problem could be a dirty/corroded socket, which can be replaced for pretty cheap at your local parts store
Allen117
11-28-2017 09:09 PM
maples01
11-02-2014 07:24 PM
MrShake
1999 to 2016 Super Duty
08-24-2012 09:47 AM
66CustomCab
08-08-2011 12:59 PM
Jeep Guy
02-18-2006 06:14 PM
Quick Reply: cigarette lighter problems
