AC suction side fitting?
Old Oct 6, 2012 | 06:43 PM
tabijan's Avatar
tabijan
I see an AC fitting above where the oil filler tube curls back towards the engine. Is this the only low side fitting? The air cleaner hoses have to be off to charge the system with the engine running? I expected to see somthing by the receiver/dryer on the passenger fender. I see a high side fitting by the radiator cap.
Sixto
'93 E150 Chateau 5.8 184K miles
Old Oct 6, 2012 | 10:22 PM
avenge's Avatar
avenge
Mine's on the passenger side near the drier, I've never seen one where both high and low are on the same side and why would the air cleaner hoses have to be off?
Old Oct 7, 2012 | 05:38 PM
tabijan's Avatar
tabijan
I just realized this van was delivered with R-12. I don't see a retrofit decal so I have some work to do confirming what's in there. If these are R-134a fittings, which they must be since they're not threaded, they were installed as part of a comprehensive conversion because they're not the kind that fit over and destroy R-12 fittings.
Here are some pictures of the engine bay:
Passenger side overview, no fittings -
Detail of drier with low pressure switch, no fittings -
Detail of evaporator box, no fittings -
Detail of accumulator with fitting (cap removed), looks high side to me -
Fitting near where the oil filler tube turns towards the valve cover -
Detail of previous fitting -
I can't reach the fitting without removing the hoses that lead from the air cleaner to the throttle body. I suppose I can reattach the hoses once the guage set is hooked up. I can't imagine that's where Ford originally put the fitting.
Where's the suction side fitting in your van?
Unrelated view of second and third row captain chairs and late model 4-passenger bench -
Sixto
tractormanbill
36
Apr 9, 2018 11:18 PM
jackietreehorn
17
Jul 23, 2017 11:46 AM
richardfine
Aug 3, 2016 02:27 AM
tractormanbill
Mar 2, 2015 06:51 PM
EXv10
Mar 27, 2013 11:44 PM
