Crossovers Edge, Taurus X, Freestyle, MKX, Flex etc.
pure synthetic oil
Old 09-03-2012, 07:01 PM
hillbilly1025's Avatar
hillbilly1025
hillbilly1025 is offline
pure synthetic oil
2012 edge 3.5
since there is such a long time between oil changes on these vehicles, is there any benefit to running a true synthetic like royal purple?
Old 09-08-2012, 09:55 AM
steve(ill)'s Avatar
steve(ill)
steve(ill) is offline
synthetic oils are made for peple that are putting 5000 miles a month on a vehicle and dont want to change the oil that often. If you are putting 1000 - 1500 a month, i think your still better off to change the oil every 5000 miles or 2-3 times per year. If you drive less than that, i would change the oil every year. The bad thing is to leave the oil in for LONG periods of time.
Old 09-10-2012, 03:24 PM
38Chevy454's Avatar
38Chevy454
38Chevy454 is offline
In my wife's 2008, I just use the Motorcraft synthetic blend 5W-20 oil and a quality filter every 5000. About 60% highway miles and with 80K on it now the oil still comes out just a light brown color. I am sure it could go longer, but every 5K is easy to remeber and keep track of. Plus doing oil change myself it is relatively low cost ($20 range).
Royal Purple is excellent oil. I think overkill for an Edge. If you really want to understand the oil change interval, you need to do used oil analysis and it will let you know when the oil is due for change.
Old 09-12-2012, 10:57 AM
NathanKross's Avatar
NathanKross
NathanKross is offline
Originally Posted by 38Chevy454
In my wife's 2008, I just use the Motorcraft synthetic blend 5W-20 oil and a Aftermarket Parts filter every 5000. About 60% highway miles and with 80K on it now the oil still comes out just a light brown color. I am sure it could go longer, but every 5K is easy to remeber and keep track of. Plus doing oil change myself it is relatively low cost ($20 range).
I wanna put synthetic in my 1994 ford focus, however I heard that switching to synthetic will break down old oil deposits is this true?
Old 09-13-2012, 11:35 AM
YoGeorge's Avatar
YoGeorge
YoGeorge is offline
Why consider switching on a 20 year old car? Too much money in your wallet? Especially if you don't drive a lot of miles, use regular or syn blend oil and pocket the savings for a new car. Or take your wife/gf out to dinner.
George
Old 09-13-2012, 06:06 PM
38Chevy454's Avatar
38Chevy454
If the engine has had regular oil changes, it should not have a lot of deposits. Synthetic does tend to be better at removing any deposits compared to dino oil. Just have a good filter and I think you will be fine, assuming the engine has had regular oil changes in past.
You might try a synthetic blend for a few oil changes before pure synthetic?
Old 09-13-2012, 07:48 PM
Muffinman's Avatar
Muffinman
Muffinman is offline
I always flip out when I see this question. If you change your oil every 5k miles it should be ok to switch. Then the other side says if it has build up no, it will screw your engine up. Which is crap science, if its dirty clean the engine out with a higher detergent oil, which all major brands syn use. this will clean the engine out. Just use a damn good filter and change it an extra few times tell the build up is gone.
If the engine has big *** chunks of sludge. No matter what the hell you do, the engine will fail if it blocks enough oil returns to start with. If you want to know if your engine is clean pull a valve cover and you will know.
Old 09-14-2012, 05:34 PM
steve(ill)'s Avatar
steve(ill)
what YOGEORGE said-- YEP.
Old 09-18-2012, 07:07 AM
kw5413's Avatar
kw5413
kw5413 is offline
I use Mobil 1 in all of my vehicles. On my MKT because of low mileage. My company is about six minutes from the house and most of my daily business is in that same range.
My company truck has 125,000 miles. Now it only drives about 5,000 miles a years so most of the time it backs out of the shop in the morning a pulls into the shop at night. So it gets the Mobil 1.
Old 09-18-2012, 09:49 AM
merlynr's Avatar
merlynr
merlynr is offline
94 FORD FOCUS................???
Old 09-18-2012, 04:41 PM
dundonrl's Avatar
dundonrl
dundonrl is offline
Synthetic is made for engines that see more abuse than your average engine. That could be a granny doing 40 mph 3 miles a week, or Joe Stick shift doing WOT every time he gets in the car, and seeing closer to 200 than 100 mph.
This is why cars such as all 97+ Corvettes, all AMG, Porsche etc cars come with Mobil1 from the factory.
Old 09-18-2012, 10:45 PM
Papa Tiger's Avatar
Papa Tiger
Papa Tiger is offline
Temporarily Deactivated
Received 3,432 Likes on 2,347 Posts
If you live in an area where the temp never goes below say 15 degrees F. you will probably see near 0 wear for 100,000 miles with high grades of synthetic motor oils changed properly with the best filters. Cheap plastic parts breaking is another story. They will probably still wear and break.
Old 11-09-2012, 10:02 AM
KhanTyranitar's Avatar
KhanTyranitar
KhanTyranitar is offline
There is no such thing as a 1994 Focus. The Focus was introduced in 1998 in Europe and in '00 in the US. So good luck with putting any kind of oil in your '94 Focus.
Old 11-11-2012, 07:00 AM
thmitch79's Avatar
thmitch79
thmitch79 is offline
2 Edges, 07 and 10, 02 F150 5.4L and a '03 Southwind Motorhome with a V10 6.8L....all get 5W20 Ford Semi Syn every 7500mi and not a lick of issuses. Oil is clean going in and clean coming out. Just use a good filter.
macguy
6.7L Power Stroke Diesel
18
09-24-2013 09:59 PM
waterboy_fishing
04-13-2013 06:50 PM
Delta2142
6.4L Power Stroke Diesel
19
01-27-2013 07:02 PM
hotrodracer
1999 to 2016 Super Duty
09-13-2009 11:45 PM
FordF350Baby
Oil & Lubrication
19
08-03-2008 11:28 PM
Quick Reply: pure synthetic oil
