need flywheel input *now with clutch issue
Can someone give me a quick overview of what to look for when messing with the flywheel/starter?
Scenerio: I just bought a 79 f150 4x4 with either 351m or 400, 4spd. I got it cheap because they burnt up a starter trying to start it, just to find out the motor was locked. I paid, got under it, spun the flywheel backwards and got the jam out (they said they already pulled a couple starter pieces out). Put a new starter and only got grinding. I'm not sure if I had the wrong starter or the teeth are too torn up or both. Pop-started it and drove it onto the trailer.
NOW, I need to get it startable. ring gears are cheap, so I'm gonna put a new one on, but I want to make sure it has the right flywheel while I'm in there, and also get the right starter. I can't remember what it should be, any help??
Restoring American History | Mustang Parts | Camaro Parts | Chevelle Parts | Ford Truck Parts | T-Bird Parts | Firebird Parts $164.95 and that is with a ten second google search i bet you can find better deals the more you look
I just went through a similar issue, there is a difference between the 351 and the 400 flywheel. My original 12" flywheel had a 2" crack and had to be replaced. The 400 required the 180 tooth 12" flywheel. I found a close match on Craigs List but it wasn't perfect so I had to do a Franken-Clutch assembly to get it working.
Here was my original clutch and flywheel assembly.
The clutch on the left is my new replacement that fit my new 11" flywheel. It wasn't a perfect fit but it worked. My long term fix will be to find the correct 12" 180 tooth flywheel, I already have the correct (New) clutch assembly.
I hope this helped.
I hope this helped.
1977/79 F100/350 / 1978/82 Bronco / 1980/82 F150/350.
D7TZ-6375-E .. Flywheel - 180 teeth ~ Use with 11" clutch & 351M engine.
D7TZ-6384-A .. Flywheel Ring Gear - 180 teeth.
1977/79 F100/350 351M/400 / 1978/82 Bronco 351M/400 / 1980/82 F150/350 351M/400 / 1983/97 F250/350, F(Super Duty) 460.
ok, new issue. P/O said they got broken pieces of starter out of the bell when they messed with it. I now know that it was not starter pieces, but clutch pieces. Clutch was working fine, but I just got it all apart and found that all but one spring are missing, and that one is broken. Clutch looks great, but is now junk. What causes that? Is the PP still good? Can I get a new clutch disc or am I stuck buying a whole set?
<a href="http://photobucket.com" target="_blank"><img src="http://i12.photobucket.com/albums/a204/KBrian/parts%20and%2089/D1276B88-CE89-4FE5-BEDD-3E303B863FB4-1596-000000ABE0317585_zpse0b87085.jpg" border="0" alt="Photobucket"></a>
<a href="http://photobucket.com" target="_blank"><img src="http://i12.photobucket.com/albums/a204/KBrian/parts%20and%2089/F3B2A109-BD5E-43BF-BC26-368A41A715FC-1596-000000ABFC5AFAA3_zpsaeaf7ad6.jpg" border="0" alt="Photobucket"></a>
<a href="http://photobucket.com" target="_blank"><img src="http://i12.photobucket.com/albums/a204/KBrian/parts%20and%2089/EAC65F14-2AF7-4574-89C3-FA544C9B6075-1596-000000AC2D8176E3_zpse5ff5f91.jpg" border="0" alt="Photobucket"></a>
<a href="http://photobucket.com" target="_blank"><img src="http://i12.photobucket.com/albums/a204/KBrian/parts%20and%2089/7597BB97-42BF-4A53-9C07-EBDB5DF5108B-1596-000000AC52518417_zpsbdcf988a.jpg" border="0" alt="Photobucket"></a>
<a href="http://photobucket.com" target="_blank"><img src="http://i12.photobucket.com/albums/a204/KBrian/parts%20and%2089/240979DD-5076-4ED4-9584-05333A9E8325-1596-000000AD7A2F3482_zpsbf3e45d5.jpg" border="0" alt="Photobucket"></a>
now I really wish you'd posted sooner or I had'nt scrapped these parts...would've traded you for the bumper in your other thread...
that sux, but I just got the truck and didn't know.
on a side note, I found some of the springs :P They were hiding behind the flywheel, engine side.
<a href="http://photobucket.com" target="_blank"><img src="http://i12.photobucket.com/albums/a204/KBrian/parts%20and%2089/46484A46-3387-4B38-A59A-56FD351D5E67-1976-000000C6367E0765_zpsa09cf000.jpg" border="0" alt="Photobucket"></a>
1984F-150
09-13-2023 03:18 PM
kameronth
17
01-21-2019 10:21 AM
59Terry
13
10-15-2006 12:27 AM
j.foster62
01-06-2004 09:06 PM
