Heavy Duty Door Hinges
So I have a big audio system going in my 94 CCLB. The front doors are getting about 70lbs added to them with speakers, tweeters, fiberglass, deadener, and an amp etc.
I'm planning to rebuild the hinges with new bushings, new pin, etc. However, I'm not sure the original hinges will be strong enough to hold up to the weight.
Has anyone out there rebuilt their hinges to be stronger, or is there a company out there that sells beefier hinges than the oem ones?
Thanks for your help guys.
Why? Just remove the seat and make an incloser. the door panels will stick out so far they re going to hit the seat otherwise.
And what speakers are you using that weigh 20lbs and tweeters that weigh 8?
Also, the hinge is stronger than the door, I would be more concerned about fatiguing the sheelmetal
JoeVR5
02-21-2010 07:18 AM
oldtexasdog
06-07-2009 04:01 PM
fordinmudd
01-06-2007 02:28 PM
