6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
What parts can be removed from a 6.4 ?
Old 09-23-2012, 12:29 PM
Dim Sum's Avatar
Dim Sum
Dim Sum is offline
Originally Posted by parkland
Yes you would, and also liquids to not simply jump in temperature from being compressed.
That couldn't be more thermodynamically wrong.
Old 09-23-2012, 01:08 PM
vloney's Avatar
vloney
vloney is offline
OK so I did a bunch of forum reading, and asked a few people as well.
I have a verdict now.
The fuel cooler is required, but the heat isn't generated by the pumps or anything, it's just the under hood temps and engine temps that raise the temperature.
Whenever you compress the fuel, heat is generated.
The fuel that doesn't get used goes back to the bowl, so it can build up with heat.
If it went back to the tank, a small passive air cooler would be enough.
Ya know, there's a fuel return, right?
Old 09-23-2012, 10:57 PM
parkland's Avatar
parkland
parkland is offline
Minimal, minimal heat is generated through compressing a liquid.
The fuel return only returns some of the fuel.
Old 09-24-2012, 12:34 AM
Dim Sum's Avatar
Dim Sum
Dim Sum is offline
This is true, but these engines do not compress liquids b/c that would mean they pretty much defy physics.
Compressibility is defined as the ability to change a medium's density. We can compress gases due to intermoleduclar spacing. Liquids and solids are considered incompressible until you get over 10000 bar or so when we get to regions of plasma.
These trucks pressurize liquids...which is different and whenever you put work into a system, you increase temperature (indicator energy in a medium). In this case, the fuel temperature is increased via the pressurization of the fuel.
The fuel temperature needs to be controlled in order to have a more predictable ignition timing which is important when engineers are metering fuel and injection timing for proper ignition.
In short, if you heat that fuel up, you are going to impact the ignition timing and can cause damage to the engine.
Old 09-24-2012, 03:35 AM
ETKMS's Avatar
ETKMS
ETKMS is offline
What for? to have less issues? i bet you will have less issues if you leave it how it is rather then playing the trail and error game. You wanna remove something you don't need? remove the bed of the truck, it will run just fine without it!
Old 09-28-2012, 11:23 AM
parkland's Avatar
parkland
parkland is offline
There is a lot of logic in what you are saying, but the 2nd cooling system is also a failure point, and takes up a lot of room.
Old 09-28-2012, 12:25 PM
vloney's Avatar
vloney
vloney is offline
Then take it off. Just a few bolts and hoses.
Jnm2359
05-20-2014 06:31 PM
madhatt
03-09-2014 04:17 AM
Thor77
10-06-2011 09:42 PM
PSNut
07-28-2006 03:37 PM
HeatStroked
06-25-2006 07:47 PM
Quick Reply: What parts can be removed from a 6.4 ?
