Opinions please !!??!!
I'm going to install pacesetter long tubes #70-2223's on my basically stock 5.8 in my 90 F250 going over to the right side in 2 1/2 coming together in 3" thru the converter (hi-flow) out to a 3" short Magna-flo 2 chamber muffler then exit behind the right rear tire with 3" (whew) !!!
Gonna get a new Y-pipe in 2 1/2" ... do I really need to do the "Y" in mandrel bends or just go with what the shop does??? (lots cheaper)
Future mods are a Crane 444232 cam, new lifters and 1.7 rockers and a rebuild... not building for speed just towing, torque, and MPG (and some nice noise) ... Thank you, Dave
To be honest I would get the Y pipe done in mandrel bends. Yes it will be more expensive, but you want the exhaust to flow well and making the Y pipe restrictive while everything else has good flow is just dumb in my opinion. Don't want to sound rude at all, just my $0.02
on
2.5" pipe bent in the muffler shop hydraulic bender produces a pipe with an effective cross section of less than 2" for a 90deg bend, so regardless what you put behind it your motor is breathing through something like 1.85" head tubes. I had a muffler shop Y-pipe on my 5.8 before I hand built a mendrel version and the difference between the two was night and day.
For the "Y" and the CAT I was quoted $400.00 for the job !!! How is that ??? Dave
I suppose I get some E-mail about that "blonde" crack... OH WELL ... Dave
My truck is "NON-CATALYST" on the emissions sticker.
I put my exhaust together for under $200, but I have a MIG, and I like to use it!
Dual 2 1/2" in, 3" out all welded Walker brand school bus muffler and a 3" stainless Magnaflow universal tailpipe.
It sounds like a bus.. or a dump truck.
"Throaty", but it won't rot and flows plenty for my application.
