looking to eliminate a squeak
Pedal box bushings, or the spring on the pedal, or poss. where the lever arm attaches to the pushrod eyelet. Try this - gently touch the brake pedal with your right foot (no actual pressure), and work the clutch pedal with your left foot. If you feel any "feedback" on the brake pedal, those bushings in the pedal box are shot anyway.
Then again, if changing the oil in the HPO res is "overkill", so is the Heim joint. Cheap/easy/"no-surgery" solution is the drill stop collar on the lever arm, along with a bit of brass tubing to replace the cr@ptastic plastic bushing.
Yeh, but if you have T-Rex arms, usu. you don't have much arm _strength_. I have kinda small/weak arms, and holding up the weight of the pedal box to get it in just the right position to get the bolts/nuts started wasn't much fun.
But all in all, not complicated. Here's a thread on the procedure here on FTE: https://www.ford-trucks.com/forums/9...pic-heavy.html
...and one on, er, another site: Pedalbox Bushing Replacement - 1994-1997 Power Stroke FAQ
mcdimen
08-24-2014 11:16 AM
Brad_81Ford
11-04-2011 07:56 PM
