Power heated mirrors
The tow mirrors on the Ex are heated and they bolt right up. If you get the 2003 models, they have the turn signal light built in. When I say "bolt up" I mean they physically are a direct replacement. The wires for the heating element are not in the SD, you have to run them. This is not very hard. Some ideas from myself and others: Run heating wires to a toggle switch, use a defroster switch with a timer, or run direct to power from the power window or door lock switch. SD's are powered all the time from the factory. Just did the same swap. Not hard at all. A little pricey though.
Jimmie
2003 F250SD 4X4 XLT SC SB
Jimmie
will the heated tow mirrors with the signals on them hook right up to my 2003 F250 SD? I went to 2 Ford dealers today and they couldn't answer this question, I would look myself but the truck is in the shop and I need to know ASAP because I get my 5th wheel in 2 days and I am in need of mirrors. I have power mirrors now but would like the ones with the signals but I can't get this question answered. I am more interested in the signals than the defroster but if it's no big deal to wire it I think I could handle it
Jmudweiser
18
12-02-2011 07:15 AM
