1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2003 F250 Headlight Problem
Old 08-31-2012, 07:09 PM
frank7mm's Avatar
frank7mm
frank7mm is offline
I have been trying to get brighter headlights and bought some silver star 9004 bulbs. The problem is on low beam the high beam indicator is on and on high beam the lights get dimmer than low beam. Either way the high beam indicator stays on. Any ideas?
Old 08-31-2012, 09:16 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
Sounds like you have some wires switched around.
Did you change lamp types? Or did the sockets get
changed at some point?
Sean
Old 09-01-2012, 03:52 PM
Fordflanigan's Avatar
Fordflanigan
Fordflanigan is offline
you need the 9007 bulbs, I believe thats what all superdutys take 99-07 except the XL. 9004 is flip flopped basically.
check this out.
http://www.fordtruckclub.net/forum/p...vs9007bulb.jpg
Old 09-01-2012, 08:16 PM
frank7mm's Avatar
frank7mm
frank7mm is offline
Yeah found that out this morning. What a waste of $40. Brain fade sucks!
P.S. all ways double check part #'s.
Old 09-01-2012, 10:42 PM
Rongold's Avatar
Rongold
Rongold is offline
HEADLAMPS
How did you fit the 9004's into the headlamps ??? The notches (keyways) on the bulbs are in the wrong place, prohibiting the proper installation of the bulbs.
Old 11-28-2012, 03:16 PM
drlee's Avatar
drlee
drlee is offline
I have the same problem as this but my bulbs are 9007 so thats not going to solve my problem
Ok changed the multi function switch ,tested the light switch changed relays and fuses same problem. Disconnected every ad on . High beam light on dash always on, put on low beam looks like high beam ,put on hi beam looks like very lo beam , fog lights will work all the time (shouldn't with high beam ) my lighting problem might be just a coincides with hooking up a plow . Oh by the way when the plow is hooked up it is the same, lights go out on the truck but same high low problem on the plow.
<!-- / message -->
Old 11-28-2012, 03:27 PM
BigPigDaddy's Avatar
BigPigDaddy
BigPigDaddy is offline
I know I've never forced anything in my life.
Bleishear
Electrical Systems/Wiring
10-26-2018 07:03 PM
$ledgehammer
08-26-2017 11:51 AM
Bite N Hold
09-18-2016 06:48 PM
lon371
1997 - 2003 F150
01-30-2005 11:21 AM
Dj300ford
Aerostar
12-13-2003 02:17 AM
Quick Reply: 2003 F250 Headlight Problem
