One high beam problem (goes down)
Old Jun 12, 2017 | 07:16 AM
Bleishear's Avatar
Bleishear
My low beams work fine. My high beams also come on. When I put my high beams on the right beam raises but the left beam lowers.
If you adjust the beam hieght for the highs to match then the left low is way to high. First I thought the bulb had a filament issues and changed the bulbs. That did not fix it. The headlight lenses were corroded so I replaced the headlight lenses. That fixed nothing.
Any ideas?
99 Ford Explorer, v8, AWD, XLT, 5 door
Old Jun 12, 2017 | 10:05 AM
alloro's Avatar
alloro
Sounds like one of the bulbs is in upside down.
Old Jun 12, 2017 | 10:09 AM
Bleishear's Avatar
Bleishear
Bulb upside down
it does behave like the bulb is upside down but it only goes in one way. It has three slots and one of them is at 12 o'clock in the lens. You cannot flip the bulb the other way unless I were to remove the tabs.
Old Jun 12, 2017 | 12:03 PM
Franklin2's Avatar
Franklin2
Compare one side to the other. The slots on the bulbs and the sockets.
Old Aug 3, 2017 | 03:26 PM
Ltsgarage's Avatar
Ltsgarage
Wrong
Try moving them from one side to the other. I'll bet either your bucket is wrong or the wires are switched. Put the left bulb in the right bucket an the right bulb in the left bucket. I'll bet that you figure it out right away
Old Oct 27, 2017 | 06:38 PM
FractureCritical's Avatar
FractureCritical
the bulb is probably upside down and the tabs are wrong. Put the bulb in. The locking collar should line up with the notches in the bulb flange and the housings. Compare it to your other side light where it probably all lines up right. If it’s wrong, cut the tabs and line the notches on the bulb with the housing. The o-ring will hold it in position.
Old Oct 26, 2018 | 07:03 PM
ericwudi0830's Avatar
ericwudi0830
Its def not the bulb. Are your headlights adjustable?
bwguardian
Mar 4, 2019 09:12 AM
Dockmaster1
Dec 17, 2018 09:23 AM
homer4.2
Dec 11, 2009 03:33 AM
is300wrx
2004 - 2008 F150
19
Jul 24, 2006 12:48 AM
lon371
1997 - 2003 F150
Jan 30, 2005 11:21 AM
