Speedo not working still.
on
Ok so we tried hooking up our speedometer again and still nothing. I just put in a Speedo cable and checked it at the transfer case and the dash all hooked up. But not working what could be wrong?
By the way the truck is a 1984 Ford Bronco 2 4x4 manual tranny.
Trav
Trav
Trav
Trav
If it does work make sure the inner cable is long enough to engage both the speedometer and transfer case. If engaged at the tc you should not be able to turn the cable from the speedo end.If you can and are sure it is engaged pull the gear out and check for damage.
This should narrow your search for the problem
It's possible,hold one end of the inner with needle nose pliers and try and turn the other end.....if it turns it's broken.
Bad 674x4
03-29-2013 09:39 AM
stangbanger
07-10-2009 07:25 PM
RTM
02-19-2004 04:29 PM
