tail lights
tail lights
i have an 89 ford ranger custom and my driver side tail light works just fine but my passenger doesnt work when i mash the brake the passenger side brake light wont come on. the parking lights work, turn signals, and hazards work but the brake light. ive checked the wires and replaced the socket and still the same problem so either theres something in the wires that im missing or i dont know what else. any hints?
ive already done your idea ford freek and as to the switch if your talking about the turn signal switch ive already replaced that a few months ago. ive tried about everything i can think of and nothing seems to be doing the trick. ive checked wires, tested parking lights with brakes, and a bunch of other things so unless my rewiring the brake lights screwed with it thats the last thing i can think of. when i rewired i wired from switch to hot wire and from the other side to where it all ties in together right after it ties in with the trailer light and brake light wires.
The multifunction (turn signal) switch connects the turn signal flasher or emergency flasher or stop light switch to the same wire which goes to the right rear bulb. Thats why it looks like the turn signal switch is bad.
If you're sure the switch is good then i dont know what to tell you.
OOPS, in that case the best thing for alex to do is go to helminc.com & order the ETM/Electrical troubleshooting manual for an 89 Ranger. Best $16.50 he will ever spend on a manual for his truck.
pittdog1977
06-03-2014 09:53 AM
breadstick
13
03-19-2012 08:32 PM
