Extended Crank Time
Extended Crank Time
Recently I have had a problem with needing to crank the engine longer before it lights. I pulled a P0341 and P1335. I cleaned the EGR valve and replaced it. When the engine does start there it almost always a puff of black smoke out of the exhaust, and when the engine is cold I believe there it be a raw fuel smell to it. Can a fault with the CMP sensor/circuit cause this or do I need to look at something else? Also want to mention I am getting slightly better fuel economy than usual.
GOODOLEF250
17
06-22-2019 04:52 PM
strokersace
60
12-14-2009 09:13 PM
g0ldrush
09-07-2004 08:56 PM
