power window help needed
Old 08-17-2012, 09:59 AM
captain2207's Avatar
captain2207
captain2207 is offline
How would I test window relay,motor etc on my 95 f150.?the symptoms is that I hear motor turning but I have to pull up by hand as I push button.bad motor?on way down it seems to fall a couple inches,in incraments.thanks all
Old 08-17-2012, 11:19 AM
92 Black Nite's Avatar
92 Black Nite
92 Black Nite is offline
One of the common problems with Power windows that you hear the motor running but the window will not go up is in the motor gear box. There are little plastic disc that wear out . Here is a very good link that is for this issue that one of the guy's on this forum posted. From your description I would check this first. It really is not a very hard job to do.
Power Windows - Repair Part One
Hope the helps, '92
Old 08-17-2012, 11:27 AM
rla2005's Avatar
rla2005
rla2005 is offline
Received 1,172 Likes on 926 Posts
Redneckfordf2502002
09-27-2023 05:05 PM
BocceMon
07-25-2016 01:57 PM
tpd475
1997 - 2003 F150
09-13-2006 12:47 AM
Cameo
1978 - 1996 Big Bronco
06-02-2003 10:22 PM
SplashMan
01-31-2002 08:08 PM
Quick Reply: power window help needed
