power window help needed
Old Aug 17, 2012 | 09:59 AM
captain2207's Avatar
captain2207
How would I test window relay,motor etc on my 95 f150.?the symptoms is that I hear motor turning but I have to pull up by hand as I push button.bad motor?on way down it seems to fall a couple inches,in incraments.thanks all
Old Aug 17, 2012 | 11:19 AM
92 Black Nite's Avatar
92 Black Nite
One of the common problems with Power windows that you hear the motor running but the window will not go up is in the motor gear box. There are little plastic disc that wear out . Here is a very good link that is for this issue that one of the guy's on this forum posted. From your description I would check this first. It really is not a very hard job to do.
Power Windows - Repair Part One
Hope the helps, '92
Old Aug 17, 2012 | 11:27 AM
rla2005's Avatar
rla2005
Have a read through this thread: https://www.ford-trucks.com/forums/1...krewin-up.html
Redneckfordf2502002
Sep 27, 2023 05:05 PM
BocceMon
Jul 25, 2016 01:57 PM
tpd475
1997 - 2003 F150
Sep 13, 2006 12:47 AM
Cameo
1978 - 1996 Big Bronco
Jun 2, 2003 10:22 PM
SplashMan
Jan 31, 2002 08:08 PM
