Door Card Interchange between 8th & 9th gen
I spent the day at the junkyard today and came up empty trying to find gray inside door handles for my 8th gen truck ('87 - '91). Instead what I did notice is that the handles for the 9th gen trucks ('92 - '96), are much better quality, but they don't mount the same. Which leads me to the question at hand...
Can I swap the entire door card from the 9th gen truck onto the 8th? Obviously they'd both need to have the same type of window raising mechanism (mechanical vs. power).
Are they a little larger and thus interference with the surrounding trim panels is the problem? Sounds like you're speculating (and that's fine lacking any hard data), but has anyone actually done this?
Just to follow-up on this thread, pasting a data-point from another related thread below. Coupled with Brad's comments above, it sounds like it's probably a bad idea so I won't further investigate...
Originally Posted by White 97 xlt
I'm thinking that would be more of a cosmetic Downgrade since there will be a very noticeable mismatch where the door panel and the dash meet...
https://www.ford-trucks.com/forums/1...l-removal.html
emgee
05-21-2012 04:49 PM
